- May 28, 2010
- 1,933
- 5
- 0
That doesn't look like a dead pixel, it looks intentional to me. Is that the side you have setup to swipe from?
I must be crazy right? I can't have waited this long to have dead pixels? For context it's on the lower left edge.
Does it show up within other apps that have a white background (like Chrome)?
Anyone else have this issue
You should return it. It's okay. They will replace it. This is an unacceptable defect.
Called them, they said it wasn't "in their system yet" to do a return. AT&T is ridiculous. He said to call in 48 hours or so and they should be able to do it. I'll probably just go to a store on friday and buy a new one and then start the return process for this one. Total pain.
Hey man it's alright it could happen to anybody. Unfortunate that it happened to you so soon. But it's okay. Don't worry! You will get a new phone and everything will be alright.
i would see if the store can do the exchange for you right there. there is no reason they can't do it in store.
Get used to them if you return it to a store phone support makes you use that store from then on for returns.I can try when I go. I made the appointment. Usually att stores and their reps are pretty useless in my experience. They always tell you to go online or call which begs the question "then what is this store for?"
Tomorrow I have the appointment and I decided on when I'm going to do. Going to buy the phone, again, outright. Before I leave the store I'm going to make sure this one is good to go. Then once I get home I'll call att and have them email me a return label for the bunk unit. I'll update tomorrow once all of that is completed. Aside from the irony of the cluster of dead pixels on my s7 edge, this phone is awesome. I love everything about and it looks sexy. I haven't been able to put it down and I'm annihilating the battery because of it.
Now change your username. Haha
