skwon09
I used Outlook on iPhone - miles better than stock email app Apple has. Same thing on Android - I'm pretty happy with what Outlook has to offer.
I use Google music manage. Works flawless.Gotta ask you guys a question. What do you all recommend to transfer music from itunes?
I've heard many recommend isyncr AND google music. Which is more preferable since I'm moving my 6S to the S7 EDGE?
Thank you.
Last one. I promise, In the new Galaxy S7 the timeout screen only shows you time that you can pick, in the Iphone I had it Manually where as I would turn the display myself and not timed. Is there a possible trick to allowing that here?
Thank you.
Kim, how did I know you'd frigging be on this post?
Posted from the 6P of Aluminum Doom
Gents Im back!
So I have 2 more questions:
- If I want to stream some video I did in the phone to the Chromecast, what can I use? I did find the ES File Explorer has a plugin which I tried but the audio kept cutting off and couldnt hear the video 95% of the time.
- Same thing with pictures to Chromecast.
Thank you!
If you don't have Google photos set, do it, besides having a cloud backup of your photos and videos it has a native chromecast plug-in that works great.
I'm not convinced on the Google Photos thing. I dont want the big G having access and using my pictures for their own stuff.... Any other options?
