Greetings. I guess I should know this by now but have never done this. I have a memory card in my S5 that is mostly storing music and pictures I will want to move to my S7. However there are a few apps that I have moved to this memory card.
I assume at a minimum there are certain system folders I should delete before plugging into the S7 due to these apps so the S7 does not get "confused" with my S5 apps. What folders do you suggest deleting?
But other than that can I just plug it in and go? I know it needs to create certain folders but assume it will not blow away anything I have stored there?
If it is safer I can of course just back it up, re-format the card, and copy what I want on. I guess just looking for the easy way!
Thanks,
BJB1
Thanks,
BJB1
