Changing fonts on s7 edge/marshmallow
Slpsht19
13
Every new font I try and download and then apply says not supported.... Anyone got a fix for this? Anyone? Bueller? Bueller?
No fix yet. Not much to do apart from pestering Samsung and hope they'll publish an update.
I downloaded a font as well as a cool theme from Samsung and I had no problem.
Where did you download the font from that your able to use? I've tried the Google Play Store and Samsung Apps but none have worked for me. Did you have to buy it for it to work?
Rooted users can pop over to the xda developers forum and download a .zip file of 150 fonts for use on the S7/Edge...
Working fonts with S7 Edge
This is for experienced and competent users. Please read the thread, carefully and thoroughly before proceeding.
ironass motto... "Flash in haste... repent at leisure!" ;)
I've gone to settings, display, font ....NOT ONE OF THEM WORK! Love the phone, hate that I'm limited more than any and ALL the Samsung series I've owned. Getting frustrated! If you respond please be detailed on where and how you got these fonts to work? THANKS 👍
You can't download them from the Play Store, you have to get them from the Galaxy Store. Samsung disabled this on the S7 and S7 Edge and marshmallow. At least for now.
Open Galaxy Apps, search for a font, install, then go to the fonts section in settings. Fonts downloaded of the Galaxy Apps shpw up there.
Samsung or google whoever made the new seven update done terrible not onefony works not. One I'm big on the fonts all og them cool ones from AA hi 👋 fonts to all of them I ude to have on every samsung device they really need to fix its aggravating
Found a work around for this.
Download ifont off the Playstore.
Then, I downloaded a zip of the roboto font. Extracted it in a file manager, and it gave me the option to open in ifont. From there you can apply the font. The app itself has fonts that work with the phone now, I think.
Anyways here's the link if you wanna try it yourself :
material.google.com/resources/roboto-noto-fonts.html
I tried this and couldn't get it to work. I try to apply after opening with ifont and it just asks for the donation,won't let me set
What fonts did you find that work bc I can't find any that work
This method might have worked in the beginning but it doesn't now. Phone wants you to disable or uninstall foundation. As for buying the fonts? The Samsung store barely has anything. Unless I'm looking in the wrong place for them but I only seen a few.
When I downloaded marshmallow. The fonts was ifonts/tattoo fonts didn't work per second but was layered under the marshmallow code. I could not change fonts but it at least was still to my liking. I was not aware of Samsung secret of restricted fonts and tried to make a switch..... When I did that I am now under the "I hate these font" band.
Is there anyone that can insert this into code or replace this in the Samsung code? It seems that when I had it, it was under the marshmallow code and was at least stuck on the last font settings. I guess I am asking is there a way without rooting to insert fonts under the baseband and the overlay with marshmallow???
No there isn't. You would need to root the phone in order to get the custom fonts.
r3dpuk3
