Bodyguardz HD curved screen protector = Awesome!
The bodyguardz is holding up, no lifting, though some lint haha. It's not glass but I will say it's very smooth and does not make me feel like I am settling and that is important to me. If a glass comes out that actually works I'll try it but for now this does the job.
The 2mm recess is for cases, film type protectors are notorious for lifting when you out a case on so this ensures most cases will not cause this to happen.
Wish they went just a tad lower. I guess it's because there are thick cases out there. Mine isn't one of them so that gap, if I made the bodyguardz work for me, would've just turned into a huge lint and dirt pocket.
Ok, I guess it won't hurt to try. What's $25 more when you are talking about a $800 phone? I'll swing by the AT&T store later and pick one up. Hopefully they don't kick me out when they see I have a Verizon model :) Thanks for your info.
Can I just get clarity before I lay out anymore dosh!
The feel of this you're saying is close to glass. Would you say this is smoother then the TPU type (rubbery feel) and the PET type (film)?
Yes it's not rubbery at all, it's like 90% of the glass feel, not exactly glass but it does feel good.
Only difference is that it shows fingerprints more than glass but something is better than nothing to protect the screen.
Like the feel of the protector. Wish I could've made it work.
They have a replacement program. They would send you a new one for the price of shipping. I did it last year with an S6e screen protector from them that went on like crap.
just attempted putting the spigen curved crystal screen protector on and its trash. It won't stay down on the sides at all. Then I got a email from spigen stating that the case has adhesive problems and resend a new and improved one on march 28. I had a problem with my s6 edge plus and zagg hd lifting up on the corners and its was put on by att rep, $45 down the drain. I might have to try this one or wait for a better solutions.
I just installed one right now and I have to admit it went on pretty easy. I just ran hot water in the bathroom to cut the dust down, cleaned and dried the screen good, put one some latex gloves then peeled the bottom layer off. It is easy to line up around the home button and then I just moved it around a little to line up with the camera hole. You don't have to get it perfect the first time as long as you catch it before it lays all the way down. Once I had it straight I just let all lay out flat and I worked the air bubbles out. Once they were all out, I just rubbed the edges flat until they stayed down. I am not going to touch it until tomorrow so I'll see how it looks then.
Who makes bodyguards I ended up getting the Zagg HD then it's fine for me and I had my phone fall out of my pocket today at work animals ready to cry because I thought it had a tiny little scuff mark scratch on it. And my husband said no that's the screen protector so I guess it's worth spending $30 or whatever to get a good one on but my husband needs one so I'll recommend this one to him. I just go to the Zagg kiosk in the mall and they put it on for me. We love the glass ones but that and when bag comes out with a curved glass one I'm going to upgrade
Can you post some pictures showing you results?
Sure why not, I took the film off screen ND added this before fingers even touched the screen lol.
This was the worst screen protector I ever worked with. The edges don't even want to adhere to the edges on the screen. I trashed it. What a waste of $30.
I picked up the Bodyguardz yesterday and will give it a whirl later tonight. I hope it's not another $25. down the toilet. :-\
Odd, I had zero issue, works great, it also was not $30 for me, they retail it for $25 you sure you got the same one?
slackingfred
