Hi all,
The one downside to the edge of the screen is that most apps are made for flat screens so you lose a tiny amount of space that is part of the edge. I've been finding that this affects the keyboard mostly. Getting a case helped me prevent accidental typing with the palm of my hand against the edge but it's still hard to reach to the other side of the screen with one hand.
Swiftkey and the Samsung keyboards both allow you to reduce the size of the keyboard and move it to one side or the other to enable one-hand typing. I think those keyboards are too small. All I want to do is reduce the width of the keyboard and still keep it in the center. Most keyboards only change height. Does anyone know any keyboards that can change just the width?
Thanks.
Thanks.
