I have noticed the always on display will fade, basically grow darker occasionally. Then it'll get brighter for awhile and fade a little. Is this normal? After every five minutes does it fade a little and brighten with the time change?
I wasn't sure if it had anything to do with the brightness in the room or battery usage. I assume or hope this is committed, but I didn't know if anyone else knows of this. Thanks
