wifi to be reset after sleep
A
AC Question
using my s7 edge for some days..
after the phone goes to inactive/sleep in day or night and start to re-use it.. I have no internet connection, although wifi is still active/connected
I have to de-activate wifi and activate again and then I see all is coming alive again..
anyhow having the same symptom ... any setting to set ?
I have : keep wifi alive even when sleep (similar setting)
thank for all update/help
best regards, Guy Przytula
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,601
4,741
113
I'm suggesting that you try Safe Mode, which prevents all 3rd party apps from working. This can tell you if the problem is due to a 3rd party app, or the phone's firmware or hardware.
