Did anybody else's stock weather widget not update the time with DST? My clock on the status bar is correct but not my widget.
Hi Bryant-I think I can help you with this. I have a Samsung Galaxy S4 and I think your settings might be the same. Go to Settings, More, App Manager, All Apps. Scroll down to Weather and delete the cache and data. The correct time will then appear.Did anybody else's stock weather widget not update the time with DST? My clock on the status bar is correct but not my widget.
