This is on the Verizon Samsung Galaxy S7 Edge. But I suspect that it should be in other variants. The Verizon one has limited options in the settings
You can use the 4g switcher app or similar to change the network mode :
https://forums.androidcentral.com/e...ils?id=com.tapbase.LTEswitcher&token=8kNmI-kd
On Verizon for example if you want to force 3g,use cdma auto prl. Or you can choose lte only if you don't want to use cdma at all. To set it back to default, go to the settings and choose lte/cdma.
