'Content hidden' lock screen notifications - S7 Edge: why don't they show details?
  • Start date Start date
A
AC Question
'Content hidden' lock screen notifications - S7 edge
So I must have fiddled with one setting too much. All my notifications on the lock screen show no details, just 'Content hidden'. Which I don't want.
I've tried the workarounds from previous Android versions and the s5/s6 but nothing seems to work. Lock screen and security is set to show content and all other applications are allowed to show notifications.
Any workarounds or other settings I've missed in Android 6 would be greatly appreciated.
Many thanks!
Last try, go Settings>Applications>Application Manager>Email(for example) and under notifications it will show everything. I have content show and my settings read as follow.
Previews in pop-ups - ON
Hide on lock screen - OFF
Hide content on lock screen - OFF
Tried that too, still getting the content hidden message, hmmmm
Re: 'Content hidden' lock screen notifications - S7 edge
Do you have an exchange account? I wonder if it's a setting administrators can control
I have "previews in pop-ups" turned on on my S7 and I don't get any pop-ups for my e-mails (one exchange account and one gmail account) using the stock e-mail app. The pop-ups for phone calls and text messages work properly.
under settings / lock screen and security what does it say under notification on lock screen, if it doesn't say "show content" that could be the problem.
So if you have tried rebooting and it still doesn't work. Go to Settings --> Notifications --> Advanced, and scroll down and click the app which the content is hidden. Make sure that Hide on Lock Screen and Hide Content on lock screen are both off. I don't know how I changed that setting on some apps but somehow I did. Hopefully that works for you
I'm having the same issue where the stock email app is saying "content hidden" in notifications of new emails despite the below settings all selected properly.
Lock Screen & Security - Notifications on lock screen: Show Content
I downloaded the official Outlook app and that will show content in the notification like it should. However, apparently the Outlook app doesn't sync exchange calendar items to the google calendar like the stock email app does. I need my exchange (work) calendar items to appear in the google calendar, however I also want to see the content previews in the notifications. Any more ideas?
Go to Settings-> Lock Screen and Security -> Notifications on Lock Screen -> Content on Lock Screen -> Show Content
Try good lock in the Samsung store
I had the exact same issue. What I had to do was to re-enable lock scree security, for example I setup a pin. After entering the pin for the second time, I was presented with options of what to show (or hide) on the lock screen. I was then able to select show all. After that I just re-enabled Swipe unlock and Im now good to go.
I'm having a similar problem with "Content Hidden" with the Galaxy S7 email app provided pre-installed with the phone:
1) setting up a gmail account in the samsung email app - will show the preview in the notification bar. Just like my S5 did.
2) setting up my Exchange Active Sync causes all the samsung email app to switch to "content hidden" for both the existing gmail account notifications and the new Exchange Active Sync account i just added.
3) disabling the device administrator allows the previews to return but also disables my Exchange Active Sync email so it's not really a solution.
I talked to our exchange admins and they haven't changed anything. it seems to be something on the S7 or Marshmallow is misinterpreting the device admin settings pushed down. My S5 did not behave like this.
The kicker is - that the standard email app is really the most desirable because it syncs contacts better than the Outlook app for android. It also a double whammy because my Gear S2 is USELESS when it comes to emails due to this "content hidden" thing that happens. The Gear S2 returns "security does not allow..." when i try to read the message.:mad:
How do I get to the details of the device admin settings that are pushed to the device? I wish I had enough detail to articulate the exact issue to my exchange team. Our Exchange server is older so I suspect that in the absence of certain details Samsung / Marshmallow is flipping certain settings by default.
I'm having the same problem since updating to Marshmallow on my S6. After some investigating and playing around with Exchange policy settings I've determined that it's likely a bug in Android 6.0.1. I created a bug issue here. I think it's a misunderstanding of a feature in Exchange which then gets misinterpreted back to the UI as having to hide content even though there's not really a setting for that in the mobile device policies. :confused:
Many thanks!
Hide content in some app notifications: If you want to have notifications on your lock screen, but hide sensitive information in some of those apps (like a messaging app), first enable lock screen notifications to show content as above. Then head into settings > notifications > ADVANCED. Here you can manage the notifications of each individual app. You can opt to hide content from the lock screen here for specific apps.
That's been tried already and has no effect.
DAVIDIQ - any update on your query. I, too, am having issues with "content hidden" message on Edge 6 after the update. None of the suggestions offered seem to solve the problem
snacks1233
