blutooth keeps disconnecting
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
I would try to backup any important data and do a factory data reset and don't install any apps to see if you still have the same problem
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
no matter what bluetooth device i am using,it will randomly disconnect and reconnect. i have repaired but that did nothing.
Try unpairing then repairing the Bluetooth device and see if that fixes the problem. I see issues with WiFi when Bluetooth is enabled; however, it could also be affecting Bluetooth when WiFi is enabled. Try disabling WiFi (if enabled) and see if that also helps.
saintdaniel
5
wifi is off and have repaired, gonna repair one more time. this is my second phone also had the rebooting for no reason issue. removed iheart that fixed the reboot, now it is a bluetooth issue.
Thomas Gruver
18
similar issues. Was working great for about 5 days.... then seems to randomly lose it and I have to reboot. Mostly between my car and my Microsoft Band so far.
Thomas Gruver
18
Honestly, this phone is about to go back to ATT. Very random... but enough to drive me nuts. Even my Microsoft Lumia was near flawless in the car, and with this phone, it's hit or miss if I can use voice to text, or even make a call.
paridge
274
I had a similar problem with Myford Touch. I ended up wiping the cache partition, and that seems to have solved the problem.
