no matter what bluetooth device i am using,it will randomly disconnect and reconnect. i have repaired but that did nothing.
Try unpairing then repairing the Bluetooth device and see if that fixes the problem. I see issues with WiFi when Bluetooth is enabled; however, it could also be affecting Bluetooth when WiFi is enabled. Try disabling WiFi (if enabled) and see if that also helps.no matter what bluetooth device i am using,it will randomly disconnect and reconnect. i have repaired but that did nothing.
