Rheller82
It will most certainly not be fine. you guys can give stats all day long, but the truth is the audio sounds horrible. Also issues like clicking and popping sounds. It's just too low and flat not at all like the previous note 5. So for "high quality sound" you will need a dac.
Btw this does not apply to the exynos versions as they have a different better dac built-in. This is why you will see post conflicting on the issue.
