Hi. How do I easily switch between sim cards in my dual sim version? I´ve seen in other Samsung models that you can switch when you drag down the top menu. This is no alternative on my phone, there is just a bar that direct to the sim card settings. the bar shows my three decided options; which sim card I have chosen to send texts, which one that use mobile data, and which one that is the standard for calls. Isn´t it supposed to show like two profiles, my private profile and my job profile? And is there any way that I can connect a certain contact to always call from my private sim, and another contact to always call from my job sim?
