Vibration Question?
madkoda12
262
Hey guys, I had a question regarding the long pressing on the screen. When I long press on an empty space on the screen, as it goes to the Page panel/widget selector screen, the phone vibrates. But when just long pressing on an icon or folder to move it, the phone does not vibrate. Is this normal?
SpookDroid
Ambassador
Jul 14, 2011
19,259
514
113
That will depend on the launcher you're using. If you're on the stock launcher (TouchWiz), then yup, that's how vibration works. If you use Nova, for instance, the phone will make a small vibration on both cases.
Ruchi Chandel
