S7 Edge ATT Update Released
April Security Patch Update AT&T
Anyone else get this today? I couldn't help but laugh. They still haven't put my Note 5 on Marshmallow, but my Edge has the latest security patch. Go figure.
Re: April Security Patch Update AT&T
Got the update today on my edge as well. Apart from April security patch what else was included? no idea (No change log showed up) . But the update size is 173 MB.
Going to bet it was touchscreen improvements/performance improvements. The screen does feel a little differently in how it's reacting to me.
I got an update yesterday and applied.
How do I find I am on the latest?
Android security patch still says Feb 2016.
Always skeptical of AT&T updates, and on my G3 it updates on its own after a while so I figure that'll happen overnight...
Updated today. Lost the ability to unlock the lockscreen with fingerprints. Have to key in the pin. Anyone else?
That's just the first time after you reboot, after that your fingerprint should work.
Nope. Even after the first time, fingerprint doesn't unlock lockscreen for ne. Takes me to keypad for pin. Fingerprint still works with Samsung pay and signing into websites via stock Internet app. Just won't unlock lockscreen. Am I the only one?
Downloaded mine this morning, Android system used to be 22-25% battery and always on top, currently it's 14%. My usage hasn't changed either, I still charge and use the phone the same way.
Confirming that Android system usage is lower for me as well. Now so far I haven't had any phantom recent apps button pushes since the update but time will tell.
Where do I get it? I haven't get any notifications?
r3dpuk3
