Im on my 2nd brand new galaxy S7 edge, and still having connection issues with wifi and data-phone connection. My biggest complaint is the data connection. It'll be working fine, then for some reason, just cut out without warning, without notice. To get it back, I've got to go to settings and toggle the connection from global to lte /cdma and back to globle again to restart. Signal strength has no bearing on this. It just happens. Verizon had me try everything possible including a full factory reset, then a new sim card and another factory reset. Have done this on both phones. Both were brand new units. Ive got an LG V10 and a galaxy S6 edge and have no issues with either one of them. I also did a bit of research on line and found that im not the only one having this issue. If anyone can shed some light on the problem, it would very much be appreciated. Im ready to just ditch the S7 edge and stay with the S6 edge. That phone had been perfect. By the way, i did try the S6 edge sim in the S7 edge and the same problem persists. So it's got to be the S7 edge. Thanks.
