Hi guys, I want to use the "palm mode" options which aloud me to mute phone calls simply moving my hand over the screen but it doesn't work. What is the problem?
Yes, but it didn't worked.Did you hold your hand over the sensor?
It says the same thing, I tried both moving the hand and place it on the screen, but nothing.I don't know what your language's version says, but the English version says to place your hand on the screen or turn the phone over (face-down on a table), which is different than waving your hand over it. Basically, you need to cover the sensor.
Thanks, but I prefer another solutionPlay some sepultura or ill ninõ. You'll forget all about muting it.
Reboot your phone
You've tried turning it over?
