Jayjit Biswas
No Mobile tower indication in my Goodlock. Another one important shortcut is missing auto snyc option.
I just installed the latest version. Could be my imagination, but the fingerprint unlock option seems to register much faster now.
There used to be a way to collapse persistent notifications so they didn't take up real estate on the lock screen. Anyone know how to do this?
I really liked it, but didn't like the new app switcher that shows all the apps in a list. Does anyone know if you can turn that part of it off?
Go into Good Lock settings and under 'Advanced' you'll find an option to toggle back to the card-style recents panel.I really liked it, but didn't like the new app switcher that shows all the apps in a list. Does anyone know if you can turn that part of it off?
So could I use Good Lock and still use Action Launcher? Or is Good Lock a launcher by itself?
11 came out the other day but I can't see one thing new or different with it. Still very good though.
Yeah I installed it but no visible changes. Probably under the hood.
Posted via my Titanium S7 Edge!
I previously used this and liked it, but I had issues with it on my Note 5. Battery would go quick, as well as quick reboots, where an app would end and it would say my phone restarted. I I installed it, and was still having issues. I ended up having to do a factory reset.
Is this version better?
