Hi, the past 2 days I've started having issues with my SD card. It's mounted and the startup check doesn't report any errors. It shows up in file explorer, and shows the free space correctly (I have all my music and photos on the card, I know I have about 17GB free, and that's what file explorer shows as does Windows when I connect to my PC). But the files and folders are not showing up.
The first time this happened, I was able to use the smart manager app and it found the files, but the folders were prefaced by a 5-digit number that wasn't there before. In that instance, I reboot the phone and everything came back.
But this time, I've reboot several times and it's not getting fixed.
Not sure what to do, looking for some advice please.
Pete
Pete
