TMavC5 Well-known member Nov 19, 2012 1,421 135 63 Visit site May 18, 2016 #1 (AT&T Brand) Since the update, MICROSD no longer appears on the notification after reboot?
ABOSWORTH007 Well-known member Oct 8, 2013 1,442 14 38 Visit site May 18, 2016 #2 Re: Anyone noticed after S7 Edge update on AT&T that the Micro SD notification is no longer present? I hadn't noticed until I read this thread but I just confirmed by doing a restart. Glad they got rid of that useless notification.
TMavC5 Well-known member Nov 19, 2012 1,421 135 63 Visit site May 18, 2016 #3 Re: Anyone noticed after S7 Edge update on AT&T that the Micro SD notification is no longer present? ABOSWORTH007 said: I hadn't noticed until I read this thread but I just confirmed by doing a restart. Glad they got rid of that useless notification. Click to expand... Ok cool. I wasn't sure if anyone else seeing this.
jneusch Well-known member May 18, 2011 1,148 31 0 Visit site May 19, 2016 #4 Re: Anyone noticed after S7 Edge update on AT&T that the Micro SD notification is no longer present? Yes Posted via the Android Central App
B bullittmustang Well-known member Jul 7, 2013 148 0 0 Visit site May 19, 2016 #5 Re: Anyone noticed after S7 Edge update on AT&T that the Micro SD notification is no longer present? Yes
felloffthetruck Trusted Member Mar 31, 2013 8,609 21 38 Visit site May 19, 2016 #6 Re: Anyone noticed after S7 Edge update on AT&T that the Micro SD notification is no longer present? The problem is still there, only the notification has been stripped away.
pounder001 Well-known member Nov 9, 2009 681 12 0 Visit site May 19, 2016 #7 Re: Anyone noticed after S7 Edge update on AT&T that the Micro SD notification is no longer present? agree no more notification and I've had no issues with my SD card
B bullittmustang Well-known member Jul 7, 2013 148 0 0 Visit site May 20, 2016 #8 Re: Anyone noticed after S7 Edge update on AT&T that the Micro SD notification is no longer present? felloffthetruck said: The problem is still there, only the notification has been stripped away. Click to expand... His original post says the notification after reboot, not the constant pop up some people were having. I
