sexy4043 Member May 24, 2016 18 0 0 Visit site Jun 30, 2016 #1 How do I remove or change the "home" on the GALAXY S7 EDGE always on screen?
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 200 63 Visit site Jun 30, 2016 #2 I don't think that you can remove home, but you can remove San Jose which is in the same time zone
M Mirest Well-known member May 20, 2013 47 0 0 Visit site Jul 1, 2016 #3 Re: "HOME" on GALAXY S7 edge Try going into AOD settings (under display settings), go into clock style, scroll to the dual time zone clock style and there should be a tiny gear icon on the bottom right. You can add/remove cities in here.
sexy4043 Member May 24, 2016 18 0 0 Visit site Jul 7, 2016 #4 The problem is that HOME is not MY home and the time is wrong in relation to Mexico.
