New to the forum here! *hi!*
For a while after i downloaded gsam i was only using 5.5% an hour. Then i downloaded nova launcher and at 7.7% i was happy with the drain and the launcher. Went to work one day and noticed a massive drain. Cant figure out why android system is using so much google play is also a culprit.
Downloaded battery doctor....it disabled some stuff in the background. It shot downto 8.8 for a 10 mins then shot back up
*update*
It was google hangouts demolishing my battery.
*update*
