Need a tad of help on what I should do. I have a Note 4 and it works fine. I play a lot of Pokemon go, but the pokemon do not show up on my screen very fast. The rest of the family, the spawn and are caught before the show up on my screen. My daughter has a Note 4 as well and she has the same issue I have. Im sure it is a note 4 issue.
I was waiting for the Note 7, but looks like it will be a LONG wait if I go down that route.
The S7 Edge might be an option....I dont use the stylus any way....
What I am worried about? My brother has an S7 edge. He said you cannot put a tempered glass protector on it AND a case like the Otterbox.
He said every time he as tried, the case is too tight and causes the tempered glass to break.
I MUST have tempered glass and a hard case. I must have a larger screen... its why I bought my note 4.
Please give me your advise.
Tim
Tim
