Hey everybody,
I just experienced the paint peel issue on my phone today but it was not just a small spot. Let me tell you what happened, I had a zagg hd dry installed on my phone since I got it in April and had problems with it coming up so I got a warranty replacement. Today I decided since a received my new case from shieldon to finally put the new zagg on and that's when I had my home button paint almost completely removed from the adhesive on the zagg. It's hard to explain but the zagg has a top sheet to help line it up on the phone and there was some adhesive on that sheet that stuck on the home button and when I took that off almost all of the silver paint was removed along with it. Just a heads up if you use the zagg hd dry that it could possibly happen.
