Re: S7 edge battery issues, drain, gsam reporting 15-25 percent per hour minimal use while on?
Tried testing some more.. found things interesting.. a sunday afternoon, leaving the phone turned off.. sitting idle over 2 hours.. maybe 1.5% per hour max drain, often much less.. then suddenly sunday evening it starts peaking again, 6%, 8%, 10%, for no apparent reason..
Another test on a monday.. idle/off again over 2 hours.. back to normal.. maybe 3% max (still not as good as 1% but better)..
Then later in day it peaks again..
From what i can see, it seems directly proportional to the amount of notifications i'm receiving.. even with them set to not turn the screen on.. maybe aquamail related, unsure.. or facebook, or mysms.. i guess the real test would be to disable all of these and test again.
For kicks i sometimes turn on the power saving mode and that does seem to at least bring it to the 3% per hour rate, sometimes closer to that 1.5 lower average.. but then there are other times it still doesnt (and i still see notifications even though it says this mode should have them disabled until you open the app)
