Just had an update via Galaxy Apps which has brought the S7 Edge AOD in line with how the Note 7's was (bar the explosiveness, natch).
No, its still not on par with that of Note 7. I don't see alerts except for missed calls and messages. No WhatsApp, Instagram or Email.Just had an update via Galaxy Apps which has brought the S7 Edge AOD in line with how the Note 7's was (bar the explosiveness, natch).
It all will come Android 7.You're quite right. I got too excited by the extra clock faces.
And really, what's the point of the update anyway? I can't tell a difference and I still don't have notifications on the AOD screen.
The main differences I notice are it now shows the battery icon underneath the time (it was above before) and the name of the song that's currently playing now appears below that.
Except there's a bug: "Big City Nights - Scorpions" seems to be stuck in there and is always showing when there is no song playing. When a song is actually playing the correct name shows up though. And still no third-party app notification icons.
I don't get it - what's so hard about back-porting the Note 7 version of the AOD in its entirety? Why are they doing it piecemeal and introducing new bugs?
I'm getting the same with PowerAmp.I updated the AOD on my S7 Edge, the only change I've noticed is that the song that is currently playing, using Apple Music shows up under the time.
I've disabled it now. I consider the 1% per hour still far too high. If you have it on battery for 10hrs then that's 10% battery drain for not much convenience. They really need to reduce that to at least 0.5%/hr
Really though, battery drain aside, it really is a fairly useless feature as it is implemented on this phone so I could understand turning it offThere's no pleasing some ...
Even if they reduced it to .5%/hr, that's not low enough for me. That's like 12% in 24 hrs!! WAY TOO MUCH DRAIN. Think about all the extra things I can do with that extra .5% per hour.There's no pleasing some ...
