GMC MaXx
I am NOT a fb beta user, current version 100.0.0.20.70 and am having the same issue.
I'm on the same version with my Pixel. I have to force close FB to clear the notification.
Thanks. This worked for me.>>>>>> FIX Samsung S7 <<<<<<<
1. Settings > Applications > Applications Manager > Facebook > Disable > Force Stop > Enable ! Shoud pop up the UPDATE > Update! Enjoy
So I tried to google this and could not find a solution or anything resembling what I am dealing with. It started two days ago, but in my notifications, I have a message that reads,"Cast device not detected." I can not remove the notification from the list and when I click on it, it does nothing. The Cast app does see all the devices in the house and can cast to them. Only way of removing the notification is from reseting it, but it comes back. I tried deleting the Cast app and it seemed to have worked. Nothing showed up all day yesterday, but then it came back with a vengeance this morning.
Has anyone else felt with this and was able to fix it?
-----> I had encountered this issue this morning and I thought my chromecast had a problem but yes it's Facebook's new update. And I think I fixed it now because,now, whenever I play facebook videos, the notification does not appear anymore.
This is what I did:
1. Hold on to the notification. Facebook logo will appear.
2. Tap the (!) icon. It will lead you to app settings
3. Tap "Force Stop".
4. Then close all of the applications that are active
LG G5 user
Looks like it is the FB app. I tried playing videos in other apps and the FB app is the only one that causes this issue.
mine is doing the same thing, and im sorry if I sound like an ***** but what is a Facebook beta app tester? This pop up is driving me nuts!!!!
