Fit24
Trusted Member
I think I finally made it! I successfully put the Yootech screen protector after at least 2-3 tries. It is now stuck well. However, my only mistake is that there is a small bubble on one of the corners. It is not directly at an end of the protector, but it is close. It can't possibly expand and move to an end where it might cause exposure the protector and start peeling it off, right?
I think your phone screen will be okay. If it starts to peel then you may have to replace it.
