s7 edge 7.0 beta thread
ab304945
1,593
54
Post your thoughts of it here.
I just installed it and i am loving it.
It brings alot of features and looks from the note 7. Blue light filter. On screen display looks the same as note 7. Theme store is the same. Settings menu is the same.
Where do you install it from
thats a beauiful thing i had to give up my note 7 very happy with my edge on verizon i am supposed to get update tomm cant wait after your post
I love the beta! So far, I'm loving the new AOD, Theme store, cleaner notification menu, Settings screen and how things are organized, better battery life management and fine tuning options, performance modes, and the better power saving modes.
At first it was very slow and laggy. But now it is fast and lag free.
It has the same device maintenance as the n7 which helped out. It had performance mode. Which is new under that
what do you have it set at leave it default or change
Just worried it can cause issues since it's not available for download as an official update. You guys aren't concerned?
Where are people finding the app. Followed instructions implicitly & it's not there.
no its offical from samsung its beta testing the new os i have done it before for lots of os when i had moto
its nice because your sporting the new os and others are not
Darn it
That's sort of the point. This is beta testing. Meaning Samsung is asking the users to help find bugs.
r3dpuk3
