Galaxy S7 Edge Tmobile Update this morning
just got this update...any news on what it is in aside from a security patch?
What is yours at. I'm tmobile and this is mine
anybody else having a wifi glitch now?
tap to turn it on and it flashes on and off and gets phone hot.. reboot fixes it but damn its annoying.
Mine is doing the same thing. If I open settings and click on wifi I will see it switch back and forth between on and off and it won't stop until I restart my phone.
Hope you're reporting to T-Mo... they can't stop a glitchy rollout if they don't know that there's a bug.
Found a work around.
go into settings, Privacy and Safety, Location, Improve Accuracy, WiFi Scanning ---- Mine is set to On which is causing the glitch. By turning that OFF i now have normal operation of my WiFi and phone is no longer laggy or over heating.
Thanks for that! It'll help a lot! :D
I also found this same glitch on my Note 4 last night.
So it may be on a lot more devices. Both are TMO branded units..
slackingfred
