Do I need Clean Master?
venom0706
258
I've used Clean Master on all of my Android phones so far. However, I noticed that the S7 Edge has an in-built Smart Manager, which essentially does the same job. So, do you think Clean Master is necessary or Smart Manager will be enough for keeping the phone fresh?
aldo82
811
I have never used anything like clean master on any of my android phones so in my opinion you don't need it. If you want that sort of functionality then yes, use the feature built in.
chanchan05
Q&A Team
Nov 22, 2014
8,519
No. You should never use anything made by Cheetah Mobile. Plus stuff like clean master and other booster apps are just selling you snake oil.
Nakrohtap
Trusted Member
Nov 16, 2011
3,078
37
In Smart Manager under Storage, it says "Powered by Clean Master". I would assume having the Clean Master app would be redundant.
Rumblee1
Trusted Member
Nov 3, 2012
1,521
3
38
You dont need clean master or any of those cleaning apps. All they do is use battery. All you need to do is go into settings, hit storage, wait for it to load, then hit cache and clear it. Takes acfew seconds.
Johnston212
1,012
Someone actually interviewed the developer and asked him a lot of questions about it, since he couldn't find that it actually did anything.
Sam_Gs7
1,277
Yeah! As pointed out above-This app it's been reported
as buggy lately. @venom0706 try both if not works
for you try CCleaner free it does oxon job..Bye
Fit24
Trusted Member
Sep 28, 2013
470
7
18
I've never used any optimizers, junk file cleaners, speed boosters, battery savers, etc. I don't think they are necessary.
Finsrepair
