Galaxy S7 Edge WiFi Turning Off and On Repeatedly
Chriswfail
11
Where is the privacy and safety setting? I have privacy and emergency on my verizon s7 edge and nothing to do with WiFi and/or improving anything there
Ali Tarahani
I've tried everything mentioned here, nothing worked. what fixed it for me (for now) was turning Mobile Hot-Spot on and off i'd suggest trying this out too.
Settings> Mobile hotspot and tethering> Mobile hotspot.
psychoflute
It's under Location->Improve Accuracy on my Verizon S7 Edge running Nougat. So far it has solved this issue for me, but it hasn't even been a full hour since I turned off WiFi scanning.
*fingers crossed*
ghuss
3
Well there does need to be an update but I found a temporary fix for my G7 Edge. Go to Settings>Privacy and safety>Location>Improve Accuracy> and Disable Wi-Fi Scanning. It worked for me, if it doesn't for you then I have no idea.
S7 Edge, Wifi turns off, Problem solved with : Settings>Privacy and safety>Location>Improve Accuracy> and Disable Wi-Fi Scanning
Thanks
Annamalai Chettiar
I'm having the same problem but I never had WiFi scanning enabled
I tried everything mentioned here and nothing works, every time i turn on wifi, my S7 EDGE powers off.
I tried the following
Settings, location, improve accuracy and turn off wi-fi.
cleared the cache for all apps
turned on Location method to "High accuracy".
turned Location "ON"
Turned off developer mode
Settings/Wi-FI,the Smart network switch is unchecked and WiFi is turned on.
disabling the location permission all apps
went to Settings>Privacy and safety>Location>Improve Accuracy> and Disable Wi-Fi Scanning. didn't work
didn't know how to turn off wifi direct
PLEASE HELP. I HAVE TIRED EVERY THING
Agentirish
