Question on using the Verizon S7 Edge overseas
omelet1978
56
Hi,
Last year I was in Qatar for several months, and I had a S6 Edge. On wifi the phone had issues with text messaging. A +31 showed up in front of numbers and when i texted people it would not go through and I'd have to manually remove it. As it turns out the +31 was some sort of country code for Qatar.
I was just wondering if this is a bug associated with the S6 or should I expect that with the S7 Edge. I had an iphone 4s as a backup phone and did not have an issue with it.
chanchan05
Q&A Team
Nov 22, 2014
8,519
The +31 should not matter in sending SMS. I send SMS with the country code like that and it works whatever phones I use. If it only appears on WiFi you might have enhanced messaging turned on.
stevealb
Active member
May 16, 2010
25
If you have assisted dialing turned on, it will insert country codes. I've used my S7e oversees with a local SIM and it's worked out well.
