Anyone try fladhing dolby atmos to S7 EDGE
Rumblee1
Trusted Member
Nov 3, 2012
1,593
42
48
About the only thing I miss on the edge is dolby atmos. I carry an axon 7 mini for media.
Dolby Laboratories Inc. has their app on Play Store - includes Atmos.
Peace. Alan
Even when I lose, I win.
Galaxy S7Edge [MM6.0.1] Daily Driver
Lumia ICON [Win10M 14965.1001] Hobby
I believe the op is referring to the built in processing that ZTE licensed from Dolby. The app you're referring to is meant to control an external device through an app.
It's not possible to fully implement because the Atmos app is reliant on the Dolby audio processor chip to create the effects it does. The S7 doesn't use that audio chip, instead using either the in house Samsung audio chip for Exynos versions, or whatever Qualcomm uses in the S820 versions.
Mudasir
