My phone won't auto rotate at all. The option is not in Quick Settings and I can't find it anywhere else. I use Nova, and the auto rotate option is selected in Nova Settings. Any ideas?
Just to be sure, you checked the entire quick settings right? Apart from the ones on top of thr notification bar, you can swipe down on those with two fingers to reveal more. Are you on the beta firmware? Have you tried restarting?
Well, I finally figured it out. I must have inadvertently hit the auto rotate quick setting and when you do so, the name of the link changes to Portrait with a lock icon. I must have overlooked that a thousand times. After tapping portrait, the name changes back to auto rotate!
