Hi ,
I have recently discovered two issues and was wondering if anyone else had the same
1. Phone doesnt do any fast charge with third party fast chargers ( auker and anker ) . It use to work fine and then stopped working and now it gives a beep/vibration like the power is going and stopping. It works perfectly fine with Samsung charger. Did samsung make a firmware alternation to limit third party chargers ?
2. Phone when connected to Laptop cant be detected as mtp.. tried changing cables/ usb debugging/usb configuration/cache clean/hard reset. the cables just work fine with tab a. So is the port gone bad.
can both these issues be related to a bad usb [port ? did anyone else have this issue ? any advice.. thanks
