Transfering spotify to SD card doesn't work
DroidRageYo
47
Good morning all,
I've transfered spotify to my SD card from within the app itself, and it shows a checkmark next to SD card. However I noticed that my internal memory used was really high so I dug into storage --> internal storage in the settings and noticed that spotify was still listed in internal storage at a whopping 16gB.
Am I missing something?
Best regards,
DRY
BruceFlea478
24
As far as i know, once you select SD card it doesn't migrate what you've already saved, it saves anything from that point forward on the SD card. I had to erase my music downloads for offline and then redownload them again to get them to save to the SD. The app itself is still on internal memory.
asha_kanta_sharma
