1. italygrl1's Avatar
    Is there anyway to get fonts on my s7 edge without buying them from samsung individually or rooting? There used to be apps...
    02-04-2017 07:11 PM
  2. Tim1954's Avatar
    You have a handful of fonts in the device. There are hundreds of apps on play store with an infinite number of fonts to choose from..
    The galaxy store has some free ones also... Your only problem will be is to choose 😊
    02-04-2017 08:45 PM
  3. troshs's Avatar
    Unfortunately, Samsung has changed the signature of fonts allowed in the S7 Edge. Any that you download from the Play Store will likely be incompatible. Paying for fonts from the Galaxy store is kind of the only way to go. They are the only ones that work.
    younggreenanne and italygrl1 like this.
    02-05-2017 01:14 PM
  4. Tim1954's Avatar
    Oh? That's new to me.. Thanks Trosh for setting me straight. I just use the native fonts, been a few phones ago since i tried other fonts... I stand corrected 😊
    02-10-2017 09:05 AM
  5. Chriswfail's Avatar
    Trend font works but only the 1.0.3 apk.
    younggreenanne likes this.
    04-21-2017 01:03 AM
  1. I would like to buy the View but need your help
    By Sheep Creek in forum Samsung Galaxy View
    Last Post: 02-07-2017, 03:30 PM
  2. Replies: 1
    Last Post: 02-04-2017, 09:25 PM
  3. Replies: 2
  4. Is there anyway to get fonts without rooting?
    Last Post: 02-04-2017, 08:55 PM
  5. Blu Life One X HELP
    By Jmmorales in forum Ask a Question
    Last Post: 02-04-2017, 11:52 AM
