Has Your S7E Received Google Assistant?
djlee0314
219
If so, list your carrier and date update received! Patiently waiting for Google Play Services update...
Most likely your phone will notify you when the update is available.
Hopefully better than it did with the useless AOD update a few months back. If I hadn't seen it on here and went to manually check I wouldn't have known the update existed.
Like most things in the Android world it will go out in stages (as said a few posts above this). :).
I rec google assist
I'm on at&t and I rec it today
It came with the google app update in google play store. After update installed... I held down the home button on phone and the phone prompted me to set up google assistant.
I rec google assist
That's weird, I received a Google app update today but I still have Google Now.
It's not the app that has to update -- more so Google Play Services.
I do realize that sir. In fact I signed up for the Google Play Services beta today thinking that may give me access to Google Assistant, no such luck. What I meant is the poster I was commenting to said that they received Google Assistant right after they updated their Google app and I myself thought that was weird because that is not how it works. I was just trying to be nice😁
Nothing yet. Carrier doesn't matter. It'll come through the play store as an app update. But I'm on Verizon. I also have an axon7 on project fi (T-mobile), with nougat. Nothing on that yet either.
Both of my S7 Edge phones on Nougat have assistant now. T-Mobile here but the update came though the play store.
My unlocked US S7 Edge on MM has it also now.
Hello, could you tell me what type of update it was? Was it a Google Play Services update or a different update? Thanks!
It's in the play store. Look for the Google app and update it if there is an update. My Note 5 also has it now.
Ok, that is Google Now which we have all had for a while. Google Assistant will look much different. It should come via a Google Play Services update??????
Ok, I assumed that was it because someone else posted the same screenshot thinking that was it.
It will look a bit different and have better functionality. Google is rolling it out very slowly in stages. In fact I have not heard from anyone on any device that has received it yet. That's why I was like wow you got it on 3 devices already. I just wanted to confirm for myself that's all.
r3dpuk3
