03-22-2017 12:08 PM
95 123 ...
tools
  1. magerb's Avatar
    As all of you know Verizon has just released Nougat for their S7/S7 edge devices. I have created this thread for us to help each other as we transition over to the new OS. The Verizon variant of Nougat differs from other carriers and some of the help you might find elsewhere may not always apply to your specific device. This will be a one stop shop where you can come by from time to time to ask questions, answer questions and find some great information for your fantastic device.
    03-09-2017 12:04 AM
  2. magerb's Avatar
    I have been using Nougat on my S7 edge for the past 4 months. I will be happy to help anywhere I can. I will also be posting tips & tricks from time to time.
    Michael
    03-09-2017 12:05 AM
  3. mysamsungs7e's Avatar
    I have been using Nougat on my S7 edge for the past 4 months. I will be happy to help anywhere I can. I will also be posting tips & hints from time to time.
    Michael
    Appreciate that!
    03-09-2017 12:20 AM
  4. mysamsungs7e's Avatar
    Michael
    I'll start. Is high performance mode suggested for most things? I just have it set to Optimized
    03-09-2017 12:23 AM
  5. magerb's Avatar
    Everyone has different needs and different uses. It can vary on what you are wanting from your device. For everyday usage I would recommend optimized . You will overall get better battery life and stability, however, some users may not notice too much of a difference.
    03-09-2017 12:39 AM
  6. mysamsungs7e's Avatar
    OK thanks. I noticed the battery is about 15 percent better so far.
    magerb likes this.
    03-09-2017 01:08 AM
  7. magerb's Avatar
    If you do not like the new settings layout there are 2 options available for you. In settings you can tap on the overflow menu (3 dots) and there you will have the option to switch between the new layout and the one that allows you to have the quick settings you were used to having in Marshmallow. Verizon is the only carrier that offers this option.
    03-09-2017 02:11 AM
  8. magerb's Avatar
    If you are missing any of your buttons in the quick settings panel after upgrading, pull down from the top twice (or once with 2 fingers) tap on the 3 dots and then edit. Your missing buttons will be at the bottom of the screen. Also, some apps have quick buttons that may have to be added the same way.
    03-09-2017 04:06 AM
  9. magerb's Avatar
    Were you aware that Secure Folder was baked into Verizon's version of Nougat? There is an update for Secure Folder and Smart Switch the Galaxy Apps store just in case you do not have auto update apps turned on. You can also add a button for Secure Folder to the quick settings panel for it by editing the panel.
    03-09-2017 04:26 AM
  10. jmunchies1's Avatar
    Does anyone know how to get the LED working for notifications again? It worked sporadically for me after the upgrade so I hard reset thinking that would fix it but now it doesn't seem to work at all. Verified I have the correct settings turned on. Turns on when charging but not for emails or any other app notifications.
    kaufmansm likes this.
    03-09-2017 09:24 AM
  11. mysamsungs7e's Avatar
    http://uploads.tapatalk-cdn.com/201...c65393aa12.jpghttp://uploads.tapatalk-cdn.com/201...79745c911c.jpg
    That's rad thanks. I don't mind the new layout for now but good to know.
    magerb likes this.
    03-09-2017 10:14 AM
  12. toy4x's Avatar
    My Pandora doesn't work anymore. Since the update, all I get is waiting for connection cancel/retry message.
    I've uninstalled and reinstalled and still getting same message
    03-09-2017 10:57 AM
  13. Steven Cohen1's Avatar
    For me it's the Hancom Office 2014 that doesn't work. It keeps asking me to close the program but it never actually opens. I've downloaded other programs that work though.
    03-09-2017 11:35 AM
  14. dorlisa's Avatar
    Did the Secure Folder take the place for Private Mode? How do I get my pictures into the Secure Folder?
    03-09-2017 07:12 PM
  15. magerb's Avatar
    Secure Folder did not replace Private Mode. Private Mode is still there. They both have different functions.
    03-09-2017 07:47 PM
  16. jerzeygirl70's Avatar
    The. Nougat update changed my calendar. Is there a way to get it back?
    03-09-2017 09:03 PM
  17. magerb's Avatar
    What did you like about your other calendar? I posted a reply in another thread to you on how you can see your daily tasks while in your month view. You swipe up to bring up your tasks. If you don't want to see your tasks in the month view you can swipe down. It will remember whatever you leave it at. I am not aware of any way to bring the old calendar back.
    03-09-2017 10:17 PM
  18. clintw22's Avatar
    What are the differences between the two?
    03-10-2017 07:01 AM
  19. DrifterYank's Avatar
    I downloaded Nougat several days ago. I have a Galaxy S7 running on Verizon Wireless. I cannot find the Secure Folder anywhere in the Play Store or Galaxy Apps. It also does not show a button available in the settings. I know there is a third party APK version you can download but I am reluctant to do that.
    03-10-2017 07:11 AM
  20. magerb's Avatar
    Secure Folder is where you can place apps, files and data to be protected from being seen from anyone else.
    Private Mode only works with a few Samsung apps. It is toggled on and off and secures the files that have been selected within the apps.
    clintw22 likes this.
    03-10-2017 10:06 AM
  21. magerb's Avatar
    Secure Folder is not in the Play Store it is only available in the Galaxy Apps store. It is already on the Verizon variant. You have to add the button by editing the quick settings panel.
    03-10-2017 10:11 AM
  22. magerb's Avatar
    I certainly do not know all the answers to everyone's questions. With that being said, if you see an unanswered question and you know the answer by all means please post a reply. I would l like to try to make this a community thing. You there, yes you, I am talking to you😁 Thanx!
    03-10-2017 10:16 AM
  23. DrifterYank's Avatar
    Meanwhile back at the ranch: I do not see Secure Folder in the Galaxy App Store. And if I go to editing buttons in Phone Settings there is no button for Secure Folder.
    03-10-2017 11:37 AM
  24. magerb's Avatar
    I am not sure why you do not see it in the Galaxy Apps Store. In the Galaxy Apps Store try tapping the 3 dots > my apps > update and see if it is in there. Where are you going to add the button? Are you going into settings or are you pulling down the notification shade and editing the quick settings panel?
    03-10-2017 11:54 AM
  25. DrifterYank's Avatar
    If you are talking 3 dots on the Galaxy App Store there is no "my apps" option, only copy link, help and open in Chrome.
    03-10-2017 12:04 PM
95 123 ...
  1. Replies: 6
    Last Post: 03-14-2017, 02:33 PM
  2. Replies: 2
    Last Post: 03-12-2017, 04:20 PM
  3. Massive power dump (GS7E Nougat)
    By honda-Dave in forum Samsung Gear S3
    Last Post: 03-11-2017, 03:07 AM
  4. Verizon Unlocked phone and Cricket
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-09-2017, 06:50 AM
  5. S7 Edge Nougat Performance Mode
    By imlegend84 in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2017, 11:52 PM
