1. Smith 001's Avatar
    I read many complaints about the new version. Does this update bring many issues?
    I just check my phone and download the firmware, but I don't really know what this update is.
    03-13-2017 04:59 AM
  2. ZOMMBIE1's Avatar
    I updated 3 S7 edges with no issues. I personally like the new update reminds me of my Note 7 (RIP).
    03-13-2017 06:23 AM
  3. amyf27's Avatar
    I updated to nougat on my 7 Edge and have had no real problems it actually runs a little better and the battery life seems pretty decent
    03-13-2017 07:10 AM
  4. LineKill's Avatar
    I don't have any issues at all, everything is running great. The main reason you see so many people with issues is because people don't typically go to forums to tell you how great everything is. They come to find solutions to their problems.
    smvim and Christine Aflak like this.
    03-13-2017 07:50 AM
  5. edubb256's Avatar
    The update makes the phone much better.
    amyf27 likes this.
    03-13-2017 08:11 AM
  6. Hey I Tried's Avatar
    Updated and fine here as well.
    You need to remember, when cruising around forums, you're going to see a lot of people saying they are having issues. That's kind of the point with a lot of the forums.
    There aren't too many people going to post new threads saying "just updated and running fine".
    jazz70 and Smith 001 like this.
    03-13-2017 08:37 AM
  7. SgtPepper1969's Avatar
    I'm in the same boat, Nougat is available 2 download but I had a bad experience with my G4,got 5 hours of sot with LL but only 2 hours on MM so kinda put me off with these bad battery stories, I'll pull the trigger at some point??got S7E exynos in UK..
    03-13-2017 05:10 PM
  8. Fit24's Avatar
    Updated my S7 edge without any issues; liking the new changes in Nougat.
    03-13-2017 07:22 PM
  9. maher79's Avatar
    Much better than marshmallow. Update away.
    03-13-2017 08:01 PM
  10. D13H4RD2L1V3's Avatar
    Yes.
    Do note that it is best that you do a factory reset after updating as it ensures that the device will perform in the most optimal manner on the new software build.
    Smith 001 likes this.
    03-14-2017 12:34 PM
  11. Tsepz_GP's Avatar
    If you want to get a great Nougat experience, update and do a full format of your phone.
    I did this and thoroughly enjoying Nougat so far.
    LineKill likes this.
    03-14-2017 01:06 PM
  12. Smith 001's Avatar
    Thanks for your reply, I have updated mine. After two days use, I have found something really good, I like the notification bar, the nice app icons, several modes and the higher quality of video player.
    03-14-2017 11:30 PM
  13. SgtPepper1969's Avatar
    How is your battery life??
    03-15-2017 09:15 AM
  14. Tarah Sorber's Avatar
    I updated mine to 7.0 last week and i have nothing but issues. I did not factory reset it though.. i am going to do that this weekend. I must say the battery life is good though that wasnt an issue. My badges wouldnt disappear or even register that i had a notification. It kept freezing. I cant send MMS. The internet wouldnt stay connected. Hoping a factory reset will help.
    03-15-2017 11:11 AM
  15. bandofbrothers2112's Avatar
    I've been using nougat for a couple of weeks now.
    Not needed to clear System Cache or Factory Reset.
    My s7 is very snappy.
    03-16-2017 01:10 AM
  16. fredhenk's Avatar
    Not a single problem
    03-18-2017 06:23 PM
  17. Smith 001's Avatar
    Nothing big improvement, one day per charge is enough.
    03-20-2017 01:46 AM
  18. Smith 001's Avatar
    So far the only drawback I have found is the font of the notifications, a bit small.
    03-20-2017 01:48 AM
  1. My phone keeps automatically muting notifications.
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-13-2017, 07:54 PM
  2. Security Patch - January Last Update
    By jejiv in forum HTC 10
    Last Post: 03-13-2017, 08:12 AM
  3. Why do my recordings in memo app keep disappearing
    Last Post: 03-13-2017, 04:18 AM
  4. My lg stylo2 was hack
    Last Post: 03-13-2017, 03:07 AM
  5. Replies: 0
    Last Post: 03-13-2017, 01:08 AM
