Fit24
Trusted Member
I kind of like then animation on Nougat but I might give that a try. Not off but bring it down to 0.5 from 1.One thing I didn't see mentioned much here is the speed of the device and the increase with Nougat. When I turned animations off in developer options the device flies. I find it faster than Marshmallow.
What you listed above is not normal. Seems like you need a factory reset. No wonder you are hating it.
I don't like the info in the pulldown menu either. It is too small in some cases.
That would require very little effort. Surely you don't expect that do you. What's wrong with you!Most things that people say they don't like, including this one, can be adjusted in Settings.
Another thing to keep in mind is that if you turn the animations fully off the edge lighting will no longer work.I kind of like then animation on Nougat but I might give that a try. Not off but bring it down to 0.5 from 1.
Also, one more thing. My overnight standby battery is crazy good. About 3 to 4% drain in a 7 to 8 hour of sleep. My MM used to cause at least 15 to 18% battery lose overnight.
One way is to go into settings > display > screen zoom and font and increase screen zoom from medium to large.Can you help me find where? I looked in the notification settings and don't really see any options anything like that.
