1. Air Planet's Avatar
    Which microsd card is best for s7 edge from these two sandisk microsd cards and whats difference between them?
    03-18-2017 09:28 AM
  2. Air Planet's Avatar
    Other
    03-18-2017 09:29 AM
  3. Dngrsone's Avatar
    I really recommend you go with a Samsung micro μSD card for your S7E: I and many others have experienced problems with Galaxy devices when using other-brand cards.
    ToddK and Tsepz_GP like this.
    03-18-2017 09:48 AM
  4. ToddK's Avatar
    I agree.
    03-18-2017 10:14 AM
  5. LineKill's Avatar
    It would probably be best to stick with a Samsung as stated above. Oh, and 6 AED😉
    03-18-2017 10:27 AM
  6. smvim's Avatar
    Here's a handy page showing microSD card speed classes:
    https://www.sdcard.org/developers/overview/speed_class/
    and if you want to read more detailed info, this wirecutter article is worth reading through. Even if you ignore their recommendations the general info is quite relevant:
    The Best microSD Card | The Wirecutter
    thecomicbookandme likes this.
    03-18-2017 10:44 AM
  7. sparksd's Avatar
    03-19-2017 10:51 AM
  8. Air Planet's Avatar
    No also i want to know that whats difference between in these two cards from same company and same extreme pro series which images i have posted above means 1st is uhs 1 and 2nd also uhs 1 but with v30?
    03-20-2017 10:21 AM
  9. Dngrsone's Avatar
    Huh. I thought it was only my daughter that started sentences with "no"...
    03-20-2017 10:43 AM
  10. smvim's Avatar
    The 'V30' designation is for the newer microSD cards optimized for video recording. V6 for 6MB/second, V30 for 30MB/second, V90 for 90MB/second, etc. Unless you're recording video at 4K (I don't even know if the S7 Edge supports it) you should be fine with a non-V30 card.
    Go to this site and look at the 'SD speed class' chart for an easy explanation graphic:
    Dngrsone likes this.
    03-20-2017 11:50 AM
  11. Air Planet's Avatar
    It means v30 have no more than 30mb/s write speed?
    Or
    V30 also have 90mb/s write speed but with video record at minimum 30mb/s advantage?
    03-22-2017 02:07 PM
  12. Air Planet's Avatar
    Or
    04-06-2017 08:14 AM
  1. Why can't I make/receive calls? (Data and SMS work)
    Last Post: 03-18-2017, 08:19 AM
  2. How to set phone to turn off night and on in the morning.
    Last Post: 03-18-2017, 06:22 AM
  3. How do I remount my SD card
    Last Post: 03-18-2017, 06:11 AM
  4. Replies: 1
    Last Post: 03-18-2017, 05:44 AM
  5. Replies: 1
    Last Post: 03-18-2017, 04:44 AM
