1. supermarketjedi's Avatar
    Can anybody direct me to any useful information about or instructions for rooting a Samsung Galaxy S7 phone running Android 7/nougat? The operating system is brand spanking new so I haven't found too many yet which would make me feel comfortable about trying.I've never rooted a phone before. I have a galaxy s7 edge SM-G935A, which I just updated to android 7. Nougat and I just don't get along so far. I want out.
    Some General advice on what to do with it once I've done the deed would also be helpful, especially as pertains to security. I understand rooting can be a security risk if mishandled.
    03-19-2017 12:29 PM
  2. Dngrsone's Avatar
    Have you tried XDA Developers forums?
    If anyone has a good root method, it will be there.
    magerb likes this.
    03-19-2017 12:54 PM
  3. pontiac005's Avatar
    Also try the S7 edge root forum.
    03-19-2017 07:48 PM
  4. magerb's Avatar
    Here is another place for you to check out. They have your model G935A here as well.
    https://www.androidsage.com/2017/03/...erizon-sprint/
    03-19-2017 08:13 PM
  5. NexusGirlX's Avatar
    Google says this is an AT&T model. Just so you know, US versions of the S7 Edge can be rooted but since the bootloader is locked, rooting is about all you can do. You can't run custom ROMs on the phone or run a custom recovery.
    I tried rooting my T-Mobile S7 Edge and my US unlocked version which still has a locked bootloader, and I absolutely could not get rid of the lag and severe battery drain, a common complaint due to the root method.
    03-20-2017 09:25 AM
  1. Replies: 6
    Last Post: 03-21-2017, 09:59 PM
  2. Samsung Galaxy S7 Edge: S-Planner missing
    By phila63 in forum Android 7.0 Nougat
    Last Post: 03-19-2017, 01:46 PM
  3. Update killed Ir blaster?
    By kirksucks in forum Samsung Galaxy Tab
    Last Post: 03-19-2017, 12:28 PM
  4. How to pair a gear2 with a ZTE Max pro
    By AC Question in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 03-19-2017, 12:14 PM
  5. How to pair a gear2 with a ZTE Max pro
    Last Post: 03-19-2017, 12:02 PM
