1. Reggie Scruff 819's Avatar
    After installing the upgrade yesterday I am not able to alter the size of font in texts using the volume buttons on the side I know I can spread with my fingers but typing now with small font is a pain!:-
    Sam_Gs7 likes this.
    03-20-2017 04:27 AM
  2. Tim1954's Avatar
    Hi Reggie, welcome to the forums!
    Seems the Nougat update has changed a lot of things, not all of them popular... Sadly, it's back to pinching in /out...
    03-20-2017 06:35 AM
  3. LineKill's Avatar
    If I understand correctly you can try this and see if it helps. In the Messages app go to Settings > Font size and uncheck Use phone font sizes. Then adjust FONT SIZE to your liking.
    03-20-2017 09:52 AM
  4. Sam_Gs7's Avatar
    Can you comfirm @Reggie S..819 : Is this a Nougat upgrade
    or a Secure update..? I'm a bit illiterate and confuse Upgrade
    with Update: Also on this issue of Font upsizing anybody
    know how to "Pinching in--Out" Text in the AC-Mobile
    app: I tried but this feature isn't present..Any reply
    03-20-2017 10:09 AM
  5. boxer_luvr's Avatar
    Yea i have a similar problem. After the update its like the keyboard got smaller. Now i make several spelling mistakes when typing a message. Its a pain
    03-20-2017 06:40 PM
  6. LineKill's Avatar
    If your keyboard is smaller long press the 2nd key to the left of the space bar and press on the gear. From there tap on Keyboard layout. Drag the top handle up to make the keyboard larger.
    03-20-2017 07:12 PM
  7. boxer_luvr's Avatar
    Yea i did that. Maybe its just psychological. Just seems like i never had issues typing until after the update. And i like the update
    LineKill likes this.
    03-20-2017 07:14 PM
  1. S7 edge software update poses format problems
    Last Post: 03-20-2017, 03:35 AM
  2. Hpw do a block text messages on a Samsung grand prime?
    Last Post: 03-20-2017, 03:29 AM
  3. Samsung Note 4 N910T - Update to 6.0?
    By bboysmax in forum Samsung Galaxy Note 4
    Last Post: 03-20-2017, 03:16 AM
  4. LG G2 woes continue with Nougat upgrade
    By brettt777 in forum Verizon LG G2
    Last Post: 03-20-2017, 02:39 AM
  5. samsung battert drain when not in use
    By Kingjd123 in forum Ask a Question
    Last Post: 03-20-2017, 02:34 AM
