Android 6.0 Cannot get rid of stupid notification "App permission management is running notification
Hello,
I just bought myself a new phone with Android 6.0. One thing I cannot get rid of is this stupid message: "App permission management is running notification". Someone suggested go to Security and slide the bar to switch it off. Then a popup messages tick the box "do not notify", then you need to switch sec. back on. This is not working. Then there are tons of solutions of this kind:
5.1 lollipop - App permission management is running notification - Android Enthusiasts Stack Exchange
The only problem you need to have ROOT permissions. I don't want to have (nor use) ROOT permission, is this really the only solution? It's the most frustrating thing so far on this Android.
Any suggestions will be most welcome.
Pete
Hello,
Pete
