No, you can't revert as I said in my first post. And it is better, it just looks like crap. With my own wallpaper and layout I saw no change whatsoever in mine. All of us have been getting the upgrade as it updates the entire OS. You can change wallpaper and themes as you could do before. As I said, I saw no appearance change with mine.
Well I certainly saw an appearance change. That's literally my entire point. Prior to this, when I opened a folder, it would open a scroll-downable folder - not a "swipe page" folder. When I brought down the drop down, the layout would be completely different (see below example). I can quite clearly say, the previous layout Was better to me - regardless of however you feel. Coding wise, I'm sure the update was swell.
And you didn't say that - you merely said that I "can't remove it" - which I thought was obvious. Reverting is a whole other concept which I've seen to be an option for advanced users elsewhere - reverting to the previous Marshmellow look or what not.
You can change icons, wallpaper, themes, etc. Not sure what you're saying.
I want the layout to return to how it was. I go into settings, "wallpaper & themes", but all the Themes & Icons are just what my phone has now updated to - no options to select the previous style. It even says recommended & other things I can buy/get for free, but most of them just have "Image errors" with a random "network error" occurring"... whole other issue there..
Anyway; lucky for my, I have a printscreen of the previous layout. Please compare the previous link with the following for CLEAR differences before & after the update. If possible, could you step-by-step aid me in selecting the right icons/themes/whatever if appropriate, to get my layout back to how it was before?
Imgur: The most awesome images on the Internet - After Update
Imgur: The most awesome images on the Internet - Before Update
