From my work Wifi, I was able to connect with no problems just a couple days ago. Then the phone updated and now it gives me the error "Failed to obtain IP address". I went online and found out about changing the static IP, I did this and it then says Connect, no Internet. Everyone else's phones are working and my boss has the same phone as me and his is working.
Steps I have done
***Forget Network
***Changed to Static IP, got "Connected, no internet" Switched back to DHCP (Without disconnecting from Static, goes back to Failed to Obtain IP address.
***Soft Reset Phone
***Setting reset
***Factory reset
***Forget the network then Cleared the Cache
Steps I have done
***Forget Network
***Soft Reset Phone
***Setting reset
***Factory reset
